DTT is doing a general overview of the transmission, this will include installing an update kit, changing the 4 clutch pac to a 5 clutch pac, 2nd gear band swap out, and i will show you how we do an end play test on the transmission.
Chuck the owner of A1 transmissions in Kerville has kindly agreed to allow me to use his shop for the demonstrations.
We are using Joe P's truck for the demo, it is a 1999 Dodge,
a lot of what i want to go over with you guys is road test proceedures , kick down cable adjustments, vb pressure adjustments, how to adjust shift points, tps adjustments,
voltage regulator and resistor installs, a lot of what i do is not the parts, the set up in these transmissions is equally critical to how long they will live.
If you guys have pressure gauges you should bring them, any of you with digital volt meters this will be handy also.
I am getting the feeling the camground is going to be turned into a tweaking center.
Anyways , Stefan and i look forward to meeting those of you that are attending.
