Luxury 5th wheel toy hauler, remote controlled slideouts, electric awning, security lights and stabilizer jacks. 200 Watt DVD surround sound entertainment center with 32" LCD TV, outside remote for outdoor speakers, 20' awning, Corian countertops in kitchen and bathroom, icemaker, 8 cubic foot double door refrigerator, 15K BTU AC ducted and pre-wired for a second AC unit, convection microwave, 3 burner stovetop and oven, sleeps 8 (Queen size master bed, twin air mattress in dinette, two twin electric bunk-beds drop down in garage). The garage is 10' long with diamond plated sides, wheel chocks for motorcycles built-in and separated from the main living area with a sliding glass door! 5.5K gas generator with 30 gallon fuel tank (currently less than 70 hours of runtime), fuel station for gassing the ATV's and other toys, external hot/cold shower. Washer/Dryer hook-ups in the garage and 50 AMP service makes this baby ready for a full-time RV'er. Power fans in the garage and kitchen for drawing air in or out and a nice ceiling fan in the main living area. New tires, including spare. Extended warranty is still in effect until May 2014. I can't fit all of the features on this 2009 Keystone FZ302 Touring Edition here, so come take a look at all this baby has to offer and you won't be disappointed!!
200 Watt Premium Stereo with CD/DVD Player, 32" Flat Panel LCD HDTV, 4 Interior Speakers, 2 All Weather Exterior Speakers, 400 Watt Amplifier, 10" Subwoofer in Enclosed Speaker Box, A & B Indoor/Outdoor Speaker Switch
Fuzion Central Command Center
12 Volt Disconnect by Entry Door
Ducted 15,000 BTU A/C with Cold Air Dump
Wired, Braced, and Ducted for 2nd A/C in Bedroom
Insulated A/C Ductwork
Space Saver Microwave with Hood Vent and Filter 3 Burner Range Top and 22" Oven
10 Cubic Foot Double Door LPG / Electric Refrigerator
Raised Solid Wood Refer Panel
Metal Paper Towel Holder
Waste Basket
Professional Bottle Opener with Cap Catch (Bar Models)
Step Rail on Island (Bar Models)
Kitchen Sink Covers
Solid Wood Cabinet Doors
Lumber-Core Cabinetry
Screwed Cabinetry -- No Staples
Residential Cabinet Hardware
Solid Wood Drawer Frames
80lb. Rated Full-Extension Ball Bearing Drawer Guides
Overhead Cargo Netting
Halogen Puck Lights
Custom Furniture with Custom Embroidery
Hide-a-Bed Sofa with Flip-Down Arm Rest and Built-In Cup Holders (Some Models)
Huge U-Shaped Dinette with Electric Air Mattress Hide-a-Bed, Twin 2 ½' Pull-Out Storage Drawers, Adjustable Head Rests, and Built-In Cup Holders (FZ393, 302)
Day / Night Shades
Cross Ventilation Throughout - All Windows Open
Multiple Sky Windows (most models)
Vinyl Wrapped Hard Window Treatments w/Fabric Inlay
Large Ceiling Fan with Light Fixture
30" Wide Radius Entry Door w/Screen
Coat Closet by Entry Door w/Coat Hooks
Multiple Cable TV Connections
Satellite Prep
Digital Splitters Throughout for HDTV
TV Antenna w/Power Booster
Exterior Stereo Antenna
60" x 80" Residential Size Queen Bed
Storage Under Bed
2 Windows in Bed Slide - Cross Ventilation
Marble Patterned Shower Surround
Neo-Angle Textured Glass Shower Enclosure
Residential, Adjustable, Hand-Held Massaging Shower Fixture
Skylight Over Shower
Porcelain Toilet w/Foot Flush
Power Exhaust Fan in Commode Room
Mirrored Medicine Cabinet
Steel Loft Bunk Ladder (Garage Models)
60" x 80" Residential Size Loft Mattress
LPG Detector
Carbon Monoxide Detector
Fire Extinguisher
GFI Duplex Receptacles Exterior
Aerodynamic Fiberglass Front Cap w/Lights and 30% Improved Turning Radius
Attic Vents
Step Light
Security Lights
Cargo Ramp Loading Lights
Compartment Lights
LED Tail/Brake Lights
Red Slideout End Walls
Dual Battery Tray
Black Clamp Ring Tinted Safety Glass Windows
Crank Down Spare Tire and Carrier
Detachable Ladder (side mount)
Folding Entry Assist Handle w/Padding
Pull-pin Snap Jacks on Front Landing Gear
Garage
Safety Glass 5' Patio Door w/Screen Privacy Curtain w/Tie-Back
Washer/Dryer Prep
22" Diamond Plate Protection on Sidewalls
Metal RAM Air Vents (2)
8' Spring Assisted Ramp Door - No Cables Beaver Tail (7' Door on Mid Profiles)
Stainless Steel Flip-Up Work Shelf / Paper Towel Holder
Full Size 30" Wide Entry Door w/Screen Rear Screen Wall Enclosure
Gas/Oil Resistant Tuff-Ply Flooring
2500 lb. Rated Recessed D-Ring Screwed into Steel Chassis
Air Conditioner Duct
Power Exhaust Vent w/Wall Switch
Clothes Hanger
Fuel Station w/12V Pump, 30 Gallon Fuel Tank, and Static Line
Overhead Storage Cabinets (N/A w/Electric Beds on 362 or 373)
Cable TV Jack Mini Blinds
Equipment
6,000 lb. EZ Lube Axles
Flipped Axles
Low-Rise Triple Entrance Step
16" Load Range "E" RADIAL Tires
16" Aluminum Wheels
Electric 3" x 12" Brakes on Every Wheel
12 Gallon Gas/Electric Water Heater w/Direct Spark Ignition
Electric Patio Awning
Electric Rear Stabilizer Jacks
Electric Front Jacks
50 AMP Service w/Detachable Marine Power Cord
75 AMP Converter
Water Heater By-Pass
Black Holding Tank Flush
Enclosed Termination Valves
Outside Shower w/Hot and Cold Water
Generator Prep w/Start / Stop Switch, Hour Meter and Fuel Gauge
35,000 BTU Furnace
Triple 7.5 Gallon (30 lb. Each) Propane Tanks
Heated, Insulated, Enclosed Holding Tanks
Hydraulic Slideout System w/Manual Override
Construction
102" Wide Body
10" or 12" Steel Twin I-Beam Chassis
3/8" Decking on Roof 5/8"
One-Piece Decking in Living Area
1" One-Piece Decking in Garage
5" Wood Trussed Roof, 16" on Center
100% Walk-On Roof
Aluminum Framed, Fully Laminated Fiberglass Sidewalls
Expanded Polystyrene (EPS) Block Foam Insulation in Sidewalls
2" Spun Fiberglass Insulation in Roof, Floor and Front Cap
Astro-Foil Insulation in Slideout Floors
Aluminum Framed Floor
1/2" Thick Insulated Baggage Doors
Touring Edition Features:
Corian Countertops in Kitchen w/Stainless Steel Sink
Solid Surface Countertops in the Bathroom and Bedroom
10 cu. ft. Refrigerator
Ice Maker!!!
Heater in the Garage
Built-in Flush Mount Wheel Chocks in the Garage
Flush Mounted Steel Storage Compartments in the Dovetail of the Garage
Electric Ramp Door
Remote Controlled Slidouts, Front & Rear Jacks, 20' Electric Awning and Security Lights
Ipod / Computer Connections for the Stereo Head Unit
Exterior Remote for the Stereo /CD Player
Pin Box Cover w/an Integrated "Hitch Vision" Mirror
New Wheels
Trail Air Suspension
New Exterior Graphics Package
Chrome Hardware
ONLY 300 WERE MADE AVAILABLE! Oo.
Waste Basket
Kitchen Sink Covers
Halogen Puck Lights
Day / Night Shades
Satellite Prep
Storage Under Bed
LPG Detector
Fire Extinguisher
Attic Vents
Step Light
Security Lights
Compartment Lights
Dual Battery Tray
Garage
Washer/Dryer Prep
Clothes Hanger
Equipment
Flipped Axles
16" Aluminum Wheels
75 AMP Converter
35,000 BTU Furnace
Construction
102" Wide Body
100% Walk-On Roof
Ice Maker!!!
Electric Ramp Door
New Wheels
Chrome Hardware
