Engine/Transmission (1994 - 1998) Killer dow pin jig;
2nd Gen Non-Engine/Transmission Traction
Engine/Transmission (1994 - 1998) elctrical issues
Ok, is this what you want to buy,I took the front off the truck replaced the seal while I was fixing a dowel pin that had never moved a bit. :D
No, I have this kit for sale in the sale section. I could not get any more then the one little photo up with the add, so I tried posting the photo's here. I don't know if there is any intrust in the jig system any more, but here is one... . Buck.
X2
Pull the cover and fix it, the bolts need tighten anyways.
I agree, the jig method is probably quicker and easier but when I did mine the bolts holding the case onto the engine were not as tight as they should have been. And the front seal was ready to be changed anyway.
Floyd
