The KDP was a problem mainly for the 94 through 98. 5 year trucks with 97 probably being the worst year. The KDP fix came after 98. 5 with a redesign of the gear case. But as with most companies wanting to be thrifty and not loose any money, Cummins used the older gear cases they had left on the 99's. So, some of the 99's might have this problem. The hole in the gear case where the KDP is, is a stepped hole so that if the pin does come out the step will stop it. Theoretically. Hope this helps.
WD
