Killer Dowel Pin Jig
1st Gen big rig wheels
10 lug adapter
Hello:
Does anyone know where I can find the jig to drill the hole to secure the "killer dowel pin" on an 1989 Dodge Cummins turbo diesel?
I understand that there were a number of these available at one time.
Any help would be much appreciated.
Tom McGuire
Don't know of a jig ?? There is guts that drill and tap the outside of the housing were the pin is using a set screw make sure you tap it in first so its back n but its easier to use a price of metal and the bolt next to it to hold the metal over the pin
Why do a temporary repair on some thing like this? thats what it is. Your 70% there anyway with what you have to remove to set the gig in place.
Tab it and check the bolts inside holding the gear case in place, and replace the crank seal. Peirce of mind is worth a million words. Do it and forget about it. Four hours and your done.
Thank you all for your suggestions - I have ordered the tab kit and will give it a go.
I appreciate you all sharing your experience.
Tom
As stated, the crank seal will test your patients. You are making the right decision read up on it, do it and for get it.
