I am preparing to pull the gear housing cover off to take care of the killer Dowel Pin problem. To remove the cover, the fan, and the vibrator damper must be removed. I have learned that the fan has a left hand thread, but what about the vibration damper bolts? When I checked my service manual it just says to remove these items but does not say anything about thread direction. The manual also says to use a barring tool to hold the engine from turning while torquing the damper bolts when reinstalling. Is there a way to hold the engine without the barring tool? What is the available wisdom that can be shared on accomplishing this task.
I know this subject has been talked about extensively, but I have read about 5 pages of posts and don't see what I need to know so hope you will all bear with me. Please share your wisdom with me. Thanks
