I just pulled an engine yesterday that was the result of a Killer Dowel Pin. This one got pretty beat up by the cam gear, then was launched out just under the fan hub. Broke a good 3" of the front case clear off. I found the dowel, as it was stuck to the gelatinous mess of congealed oil on the bottom of the front cover. The dowel is half its original diameter, and you can see cam teeth marks on it as it "rolled" on top of the cam gear for a while before finally being thrown clear. This is beginning to happen on a more regular basis, and I'm figuring that there is a reason for this... . the 12 valve engine is beginning to reach an age where this will begin to be more normal. Vibrations, over time, will take their toll on the dowels. The other engine I pulled this week for a trashed cylinder also had the beginnings of a dowel problem. The dowel pin was about . 060" out of it's bore. I tapped it in just to see how much it actually moved. Wow!
