I have the HTB2 installed on my 05. I have the stock exhaust less the cat, and a MAC intake. The filter minder will open fully as if the filter was plugged up as soon as I step on it. If I REMOVE the filter altogether it will also show that it is plugged up. I have never heard of this, have any of you? Now for part two.
I installed the new turbo about a month ago. I have the Bully Dog DL and a Edge EZ. With the downloader on Extreme and the Edge on 3, I will only get about 36-40 lbs MAX. I have the boost elbow with the tiny hole and relief hole drilled out. Just as a test I removed the wastegate hose and I did not gain a single pound of boost. I know that these turbos will spin up to 60~ lbs or so with the WG disabled, but mine will not. I have checked for intercooler hose leaks but they are all tight and in place. Does anyone out there have a clue as to why I am not boosting ~50-55 lbs? HELP!!!
