KillerB2 flat spot...
Fuel system and 6 speed problems ??
03 with pinging at early acceleration
I was reading on the High Tech Turbo web site in the feed back section and a guy stated that with his KillerB2 he would have a flat spot while towing. What flat spot is he talking about? Would you recomend the KB2 for towing as well as hot rodding around ?:D
I have had all of the HTT turbos and like the Sledpuller the best, on my Killer B2 I had a dead spot or surging problems at 1700 to 2100 rpm if I remember right, on the HTB2 it would not cool nearly enough with my TST, but the Sledpuller pulls hard throughout the RPM's and really does a good job with the egt's. Mike
which would be a good turbo for my application (see sig) + possible injectors? Still waiting tohear back from quad on his recomendations, but the question is open to all.
I would definately go with the Sledpuller, I do not think that the other 2 turbos will cool enough when you get your injectors. Mike
I'v seen no such "flat spot" in mine :confused: It pulls hard and spools well. I'd suggest it for towing and general hotrodding. Seems to be tough too because I've huffed it hard a couple times with no ill effects.
-Scott
What kind of difference? How does it spool on the low end? Am I going to need injectors to enjoy it. I plan on getting some but just curious.
i don't know what u are experiencing but myself and a few others with the killer b had serious fluttering/surging issues. the sledpuller is a bit lagier but it's not anything like the killer b as far as surging. i think the killer b is good up to 500 hp then over that it struggles. the sledpuller handles my 600hp just fine cleans up the smoke good just a bit lagy so u have to do like a 25 lbs boost launch at times lol
