Hello everyone!! I hope all is well. As some of you know, I'm repowering a 1989 Dodge Ramchrger with a Cummins. The entire '91 Drive train is being moved over to the RC. Quite a bit is done, but there is lots to do.
I thought I'd put a couple of pics up that show the area of the KDP as well as ask a few questions while I'm in here.
This is the Cummins with the front cover removed...
The KDP is here correct? Doesn''t appear to be moving, but I'm going to tab it to be safe.
I know that there are a few bolts that I should take a look at, but I can only see three bolts that I can tighten. If memory serves me, there is a hidden one that is critical to retorque.
Should I turn the motor to expose some others? How many should I be able to retorque?
This waas a running engine when removed... but it had 240k ish' on it. Not knowing the maintenance records on it. should I R/R the Inj. Pump while it is apart? Anything else?
Thanks guys! I appreciate it.
