Kit to slide rear seat forward to have room to lie down?
Are you having trouble finding front suspension parts?
Wiper Arms and Blades
I could probably talk the wife into a quad cab if I could get the part of the seat bottom that is covered by the seat back to move forward for sleeping. Anybody know of a kit? Or will I have to engineer it myself?
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, 12cm wastegated turbo (not installed), thermostatically controlled twin 14" Permacool electric fans, intercooler (installed, not plumbed), modified 518 OD transmission, Gear vendors OD controler, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chroma-colr black, black-and-red rubber rubstrip, Cummins badges, black headlights; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. Jesus saves!
Get cracking guy! For the life of me I can't imagine how you could do that... .
The front seats recline waaaaay back. And even if you got the back seat to slide forward, you couldn't recline the fronts.
Or were you thinking of creating a large sleeping area in the back of the cab independent of the front seats?
IF that's the case, sharpen your pencil real good. The vertical seat has 'tongues' which slide into 'loops' which hold it in place and the bottom seat rotates and locks in the 'up' position. Taking the entire seat out is a breeze - 4 bolts and 2 or 4 screws.
I had mine recovered to protect the factory upholstery.
If you engineer something simple and effective, please let me know as I let my dogs back there when it gets REAL cold or XTRA HOT outside and they fall in the space where your feet belong! #ad
2001. 5 2500 SLT+, QC/LB 4x4, ETH, 6spd, 3:54 LSD, camper/tow equip. , NV241HD, Bright Silver, Snug Top, Ispro w/3 pod pillar w/tweeter, Pyro, Boost & Mag Hytec cover w/temp guage, "Plain Wrap" (no decals or emblems)
That's what I've got in mind. If it works for my wife, it should work for your dogs. My brother's coming for Christmas; I'll put his engineering education to work for a change!
I took the back seat out and built a flat shelf out of plywood. I covered it with foam rubber and carpeting. I used the same four mounting bolt holes that are used for the seat and bolted down two L-shaped pieces of 1" wide X 3/16" thick steel. 2 x 4 supports are bolted to these steel angles, and a 2 x 4 is sitting on top of these two supports, running the width of the cab. The shelf is attached to this 2 x 4 via hinges, so I can lift up the shelf at the front and put stuff under it. I have a pair of subwoofer speakers in wedge-shaped speaker boxes (they're shaped to fit under the seat if I put it back in). The front edge of the shelf has a piece of 2 x 2 screwed to the underside of it, running the width of the shelf. This 2 x 2 rests on the top of the speaker boxes. The height of the shelf is about 4" lower than the top of the center seat console lid. I have slept back there many times, but I can't quite stretch out. I'm about 5'-9" tall.
Also, since the backrest of the rear seat was no longer there, the cab got very noisy! I added some insulating material to the back wall of the cab and covered it with more of the same carpeting I used for the shelf. That made a big difference.
If I was carrying more than two passengers, I would remove the shelf and re-install the back seat in about ten minutes. Well, I can't do that now, the seat is in my folks' garage in California, and I'm up here in Washington.
Anyway, it was a simple project, and since 99% of the time I'm by myself, the shelf is much more useful than the seat. Lots of items are now within easy reach while I'm driving, yet they're out of the way. I screwed in eyebolts around the perimiter of the shelf, so I can secure things like an ice chest with bungee cords.
I don't have a Quad Cab, my truck is a '97 Club Cab, but I don't see why this idea couldn't be duplicated in a Quad Cab.
Andy
It could be duplicated, but would never satisfy our needs. We've got to use the quad cab for our family car, complete with back seat. All I want to do is be able to slide the seat bottom forward so that it gets out of under the seat back, giving me 2 or 3 more inches of width to sleep on.
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, thermostatically controlled twin 14" Permacool electric fans, intercooler), modified 518 OD transmission, Gear vendors OD controler, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chromacolor black, black-and-red rubber rubstrip, black headlights, powdercoated bumpers; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. To see my truck, copy url to address bar: [http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
]http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213[/URL]
Jesus saves!
What about custom fabricating a narrow "cot" that would fit between the existing seat bottom and the back of the front seats? It could have a short base or legs to line up height-wise to the seat bottom. Perhaps you could also have some kind of a clip system that would lock the underside of the cot to the underside of the seat bottom to keep it in place during your naps. When not in use, you could remove it and store it in the box of the truck.
2001 2500; SLT; 4x4; QC; LWB; Auto; 3. 54 LS; 265s; Camper; Tow; Sliding Rear Window; Travel Convenience Group; Cab Clearance Lamps; Forest Green
jsimpson,
Sounds like you want your rear seat to do kind of like what ford does. A few years ago before my freind bought his '99 sport, he test drove a ford. It seems to me I remember the rear seat folded down (instead of up like Dodge) and seemed to make a flat deck-like area. I thought this allowed more usable space when loading up the cab. I can't remember what the back of the seat did, if it srayed in the up-right position or if if folded down also.
Fireman Dave is on to something. It would be easier to fabricate a little fold out "extension piece" than to modify the whole seat to pull out like you want.
I had a 1990 ford f-150 X-cab and the back seat bottom would fold forward and the back rest would fold down to make a deck. This was good for loading suit cases and soforth.
Eric Pitts Terre Haute Indiana
2001 Properly Valved 2500 Qcab 4X4 auto Transgo shifts it 4. 10 LSD Prime-Loc Weston Nerf Bars Smith built brush guard Command Remote Starter Scotty Air DD stage 1’s, boost fooler, elbow 32psi boost 247hp,657tq Neophyte B. O. M. B. er
The Pitts Home Page
Member GLTDR
jsimpson- I think the "cot" idea would be good. You wouldn't be able to fold the seat down to let the kids sleep if you went shopping or something, that's the bad thing. But remember if you fold down the rear seat there's gonna be a LOT more noise in the cab because behind the seat is bare metal. But I suppose you could put some noise blocker there, like I did. Just something to think about.
Corey
1998. 5 2500, 4x4, SB, Red Sport, Agate Interior, Quad Cab, O. H. Console, Auto, 4. 10 LSD, Trailer Tow and Camper Special Packages, Mopar Aluminum Nerf Bars, Spray In Bedliner, Pioneer/Jensen System, 255/85's, Bd Adjustable Preformance Box w/boost module, Boost Elbow, 4" Exhaust Split Into Two 3" w/5" cans, K+N Scotty Style, Exhaust Blanket, Bill K's Valve Body, Etc, Etc... .
well I'm gonna work on it during the holidays to see what I can come up with. I'll keep you posted.
Jesus saves!
