Klunk that sounds like something loose in the steering mechanism on a 91 Dodge Spir
Got A Hat?
Does anyone have a Nokia model 6310i cell phone?
I have a 91 Dodge Spirit that has a klunking sound in the front when you make a left or right turn. I took it in to a shop to have it fixed. They replaced everything in the front end that moved & if it wasn't replaced they tookit out checked it out & re-installed it one example of this, where the wishbone mounts to the frame. they put new struts,wheelbearings,tierod ends, power steering unit,brake shoes,lug nuts,new tires,checked the frame to body mounts & I dont know what else.
I thought some of you Ram turbo owners might own a Spirit with
this problem & maybe someone has found a solution.
Many Thanks for your time.
-- email address removed --
We have a 95 spirit that my girl drives now. We went threw the same problem. We found a broken weld on the rear axle was causing our sound. It sounded like the noice was in the front. But it was not. To find our problem we used a set of electronic ears and test drove the car. It took about 4 hours stoping and moving the mount points for the ears to narrow it down to the rear axle.
Did they replace the rack and pinion. I have seen them pop when worn also?
