I recieved a nice Christmas gift this year, a reverse light for my Duelly. I had seen this product reviewd favorably in the TDR, and was excited to give it a whirl.
Finished work on Weds night and decided to put it together, seemed simple, and the truck had been laid up for a facelift. Found the wires, easy. Put the light over the reese reciever, ok so far. Ooops, you cant access the real nice metal encased 7 wire plug any more, and the pin for the hitch would be a bear to access. So, I look over the directions some more. Seems you have to relocate the real nice protected and welded plug using a real cheesy flash chromed bracket, supplied thoughtfully with the kit. Not acceptable.
So I figure Ill make it removable by having it slip into the reciever, so I can take it out when I tow. Now it sticks out way to far and looks like something found on a Ford. Now its late, I leave it there and go home.
Next morning my brothe comes in, he got me the light, and heads over to the band saw and hacks in two.
He apparently wasn't impressed either.
So we took the two halves and welded a section of hammered steel to form a cover and then welded that to the outside edge of the hitch frame. Now it works, spreads the light well, and makes sense.
Buy your own light and a cheap light switch/solenoid, This one isnt even sealed well, says if you install in a harsh enviroment ( like behind a truck?) you should seal it with silicone. Not impressed. Live and learn.
