I was driving about 70 on interstate when I started hearing a low ticking, thought it was just something rattling in the firewall area. About 5 miles later a really loud knocking started. I immediately left off and coasted to stop, watching the gauges. Everything was normal. Got out and checked under hood, knocking was very loud and seemed like in top end of engine. Got it back home here and started looking around. Won't knock while cold but runs horrible and constant white smoke. Dropped FASS filters, replaced, and primed. Pulled valved cover and visually checked valve train, nothing. Disconnected each injector solenoid wires and checked injectors, all right at .5 ohms. Unplugged harnesses at rocker cover and checked to solenoid, all were fine. Individually pulled wires off each solenoid, one at a time, started to check each one (manual injector kill test), and no difference from any of them. Ideas? I do have a FASS titanium 95 and DPP +50 injectors. Could my FASS just be putting out low psi? I do show code P0628 but was assuming it was because I have the FASS installed and not factory lift pump. Thanks in advance.
Jesse
2004.5 3500 NV5600
Jesse
2004.5 3500 NV5600
