Knocking, died and won't start
short oil change intervals, Ram's answer
5th wheel hitch questions
TRAMPLINEMAN
Got a 2010 5500 with 90K miles all stock. Truck started and ran good from the hotel to work. Went in the office for about a half hour, came out and truck sounded like it was knocking( missing). Gave it a little throttle and it died. Tried to restart, nothing. Thought maybe bad fuel, drained canister and put in a new filter. Nothing, just keeps turning over.
Any ideas?
got this exact problem too
fuel/water light lit on dash drained on side of road
drained filter couldnt hear in tank pump running on interstate due to noise
running engine started missing down on power then died wouldn't restart
went 35 miles died wouldn't restart died
towed to dealer,
dealer said tank fuel is bad with water this all happened suddenly?
filter choked,
dealer says all bad injectors $$ doa at dealership 6700. 00 to begin with 5400. 00 to fix that's not happening
towing out from dealer to get home dump tank flush and new injectors
pulling injectors to test, Pensacola injectors 195. 00 with 1 year warranty for 08 6. 7 so far and some new connector tubes corroded on outside still working on this project
Upon inspection of tank ,Fuel in tank was milky watery and was emulsified or in suspension ,dumped all fuel, idiot light on dash was no help went off ,stopped drained on highway ran 25 miles then died completely would not restart towed truck
truck needs better filtration a racor "separator" might be next on the buy list and or fass pump dual filter
beginning to wonder if pumps at station were blending water in as pumped from storage in ground tank ? with no visable filters at pump hose fuel is blended by pump and aerated at nozzle
dropped tank flushed rinsed wiped clean blew out
water in bottom of tank enough but not a lot,particulate matter rust or scale ,a little sugar sand too also in tank ,
in tank pump screen was restricting inlet with looks like metal scale
blew out pump inlet screen with brake cleaner and air many times clean now working with fresh clean fuel
dumped filter on engine contaminated replaced, filled with lucas fuel injector cleaner
restarted ran, rough low power missing
bad injectors
crossover tubes showing corrosion on outsides of tubes wire brushed and buffed clean stayed away from tip surfaces
any help to get # 5 and 6 injector crossover tubes out / gonna have to cut some short wrenches
now tearing top of engine down to have injectors tested egr crossover tube carboned up too 74,000 miles and this happens
new parts coming tomorrow this has become quite a project
check and listen to see if you can hear pump running buzzing in tank fuel pump ? at first I could not, after cleaning I could hear it running,
bad or restricted pickup screen on pump, trash in tank, pull tank and clean, inspect replace pump if necessary I could not,at first , cleaned working now plenty of fuel to filter can now tank came out pretty easily took longer to block truck up in the air than the service task
