Knocking on #1 injector line, is this bad?
Parker 7165 hose on push-lok fittings leak
OBDII Available Information
I noticed a knocking or could feel it when touching the line from the rail to the head. All the others have a very slight tapping I would assume is the injector pulse.
Is this normal or should I be concerned?
It idles smooth, starts easy and no excess fuel in the engine that I can tell.
Any thoughts?
I just checked and I couldn't wiggle anything, but the #1 line (front most) doesn't have any clamp support on it. Is this right?
This is perfectly normal. The #1 line has a long unsupported span which tends to amplify the pressure pulses.
-Ryan
Thats great news rbattelle, thanks alot.
I never noticed it till I relocated the compressor for pacbrake.
Well thats one less worry, thanks again.
I made up a supporting clamp for my #1 line from an old 12-valve clamp. If you make one, be sure it doesn't flex the line any when you tighten it.
