Engine/Transmission (1994 - 1998) Knocking Sound
2nd Gen Non-Engine/Transmission Need Power Window Track Roller
2nd Gen Non-Engine/Transmission rear drum brakes
I had a slight knocking sound, kind of like a hollow loud knock before I got my timing adjusted. It was barely noticable at idle. After I got my timing bumped up to 18 deg it is very noticable and loud at idle. Once I put it in gear and get moving then it goes away but then I have a ticking sound kind of like valves. I am just wondering what this sound is? Also when they did the timing the new guy messed up and forgot to change the o-ring so I ended up driving an hour and having to go back because it was leaking fuel. When they took the delivary valve off the o-ring was in a couple of pieces. I took the o-ring pieces out myself and got everything that I could see. Would this contribute to the knocking sound. I would like to get this fixed as soon as possible because it is really annoying. I am going to poke around this weekend and check things.
Thanks in advance,
Doug
check your transfer pump. when they get worn and start to wear out they tend to knock a bit. the spring gets weak and the rod starts to pound on the tappet
19mm or a 3/4" sae wrench in a pinch
I second the lift pump as the tick. Cummins #'s lift pump. . 3936316, 3931059 (gaskets times 2).
Good luck
Thanks for the replies. On the seepage around the injector can I just loosen the injector nut that holds the injector in and retighten it or do I need to replace any o-rings to cure the leakage. It seems to be leaking between the nut and the injector body.
Thanks,
Doug
