Engine/Transmission (1998.5 - 2002) Knocking-ticking-from Front Of Truck
Engine/Transmission (1998.5 - 2002) Transmission to T-Case Leak
Engine/Transmission (1994 - 1998) 370s + no plate + con ofe =
:confused: 1998. 5 3500 dually black dd3 ats converter fast fuel edge comp fuel pres trans pyro boost gauges truck has just turned 100 thousand last month I've put one injection pump in from k&s , 6 to 10 lift pumps before getting fast fuel pretty much replaced all front end parts besides left wheel bearing some bushings still stock 3 to 4 months ago this noise started it comes and goes but it doesn't start until 30 and ends around 50 but maybe its still happing but i cant here it because of the engine noise tire noise or the 4inch exhaust but it doesn't sound good the truck is know may daily driver i dent drive with the box on i hardly use it i think i've went three months without using weak huh i've taken truck to local drag strip and ran 14. 61 in 4 by 4 15. 88 in two wheel drive that was before i upgraded the comp to the drag hopes in future for bigger turbo some day this noise has to go :eek: also in traffic check engine light came on for some reason i dont know yet its still on by the way it was 98 degrees out i wasn't using the ac when the light came on i hope this noise is not from injection pump or timing gears i really need some guidance with this i really wish truck was fine so i could play with friends in indy :D :D just yesterday i replaced belt tensioner the bearing went small job with big price does anybody think it could be the valves
check engine light is know off i tried to check for codes my friend told me turn key on off three times and on the thrid leave on and a code will apear at odometer screen no code apeared but check engine light is off very happy but noise is still there
