Whew, have fun with the installation I know I did
I installed the Chase system along with the steering stabilizer and track bar. 100K mile anniversary present you might say.
Not sure where you are from, but many fasteners on my truck were rusted in place due to Michigans love of salt on winter roads (job security for the automakers???). I did this install in my garage and gravel driveway. Took me alone about 10 hours to do the front and about 6 hours to do the rear (after some modifications I wasn't expecting). Job would have been impossible without:
- Oxy-acetylene torches to free some seriously rusted fasteners
-air tools (impact wrench got a good work-out)
-tapered pry bars (useful for aligning pass through holes for fasteners)
-multiple hydraulic jacks and jack stands
-phone support from Kevin Kelly of KLM Offroad (while he was on vacation-THANKS KEVIN!) due to some rear spring issues
The front springs were by far the most difficult part of the job as they are so much taller than the stockers. I could not install them without disconnecting the upper trailing arms and rolling the front axle foreward. Then I could not get the trailing arms to align with the mounting holes while holding the springs in place and jacking up the axle. A lot of jacking truck and axle up and down seperately along with some choice colorful phrases and my tapered pry bars finally got things together. The stabilizer was impossible to compress until I used the power steering pump to do the job (thanks for that tip to Kevin). I used my floor jack to compress the shocks to allow the lower mounting points to be put in place.
Overall impressions have been good but I'm now trying to eliminate the death wobble that developed after installation. My front ball joints are bad AGAIN with only 12K on them so I could not get the truck aligned properly after installation. new ones go in Thursday along with an alignment. My 315's are sitting in the garage and the stockers back on awaiting new Toyo's as well as the prevailing thought at KORE is that they contribute to death wobble after the geometry change at the elevated ride height.
Todd
