Kore leveling kit
Fuel mileage flash...
Exhaust(ing)... I'm thinking about a Geno's MEK
I have a new Kore leveling kit I bought for my '04. 5 earlier in the year. I have not installed because of fear I won't be able to get the truck in the garage(7 ft opening). Don't want to install it then have to take it out again if I can't get it in the garage. It's close now with the clearance lights and 33's. Thinking of selling it. Unless someone can convince me otherwise. This is a non VR set. I paid $800. 00 shipped with rear shocks. I'd take $650. 00 shipped to the lower 48 states if I end up selling it.
My garage has a bit less than 7' high opening. My truck fits with several inches to spare with KORE Chase and stock tires. Even if your setup makes the truck a bit taller, you can air down the tires to get it out.
I can't believe you're going to let a little thing like "it won't fit in the garage" stop you from installing your suspension and experiencing the KORE ride and handling.
What is non VR set meam? And will it fit an '06?
They aren't Variable rate coils. it should fit the 06, but the newer coils are of the VR sort and as they compress the spring rate changes to help control bounce better I think.
I'd gladly take it off your hands if you are interested in getting rid of it. Does it come with the rear shocks also? Let me know if we can work something out. Thanks.
Phil
