Details here: TDR Privileges
If you have to ask how to mount limiting straps you probably shouldn't be installing them. Precise installation is the difference between them working and your suspension working correctly, and them either working against you limiting travel too much, or insufficiently allowing your shocks to top out and possibly to cause other damage.
I know what a limiting strap does , and that it needs the suspension to not be completely drooped to keep the shocks from topping out, and that an extra allowance has to be set in for stretch of the limiting strap.
The *KIT* from KORE comes w/ a bolt on one end and a tab on the other to be welded on, in that case I'm assuming they have at least a rough idea of where the strap is going to be positioned, which is what I'm looking for... ... . I. E. do they want the tab welded to the control arm, the axle, the control arm bracket, how much will this strap stretch, etc. etc. etc.
