geusterman
Hi boys. Been out campering through the gopher country of the West... dispensing 40 grain medicine. I carry about 4000# of BigFoot camper and ammo on a KORE Race suspension inside a 04. 5 SRW 3500.
My previous terminator was an 02 with Camper Special (overloads and swaybar) 2500 with Rancho 9000's for sway added plus Kelderman hitch rear air ride. Worked real good except for rough roads and washboards which tried to take apart my truck/camper.
So here I am. Two inches of KORE coil spring in front (very nice for occasional dirtbike and ride) levels the truck. The camper sinks the rear so bad that I added (4) 2. 5" spacers to take up the slack between the overloads and the frame stops... which help a lot. But not enough. The load is still too much for the soft springs we have. Also... sway is still an issue.
We are not going the air bag route here... like adding a Timbren rubber brick or bone hard air bag and wrecking my KORE suspension's advantages. So... Rancho's are also out... because KORE is in... .
Check out my thinking if you would. Thinking about adding a 4 spring overload pack (with some holes to pin overload spacers onto the spring pack when loading the camper on to keep my headlights off the tops of the pine trees on the highway) and good HD sway bar. That is my best thinking with the reservation that the sway bar would hurt off-road ride by transferring wheel shock to the whole rear end instead of one wheel. Anyone out there with REAL backroad warrior experience that hauls heavy and fast that could jump in here? Greatly appreciated. George (Have Guns Will Travel
