WMonroe
I have a Kubota tractor that is about 16 years old and has 1700 trouble free hours on it.
My first question is. One of the injectors is leaking what appears to be oil between the injector and the block. And I think that it is also losing some compression here because when it is cold sometimes you can popping (like air squeezing out) sound when the piston is on the compression stroke. How hard is it to pull the injector and is it just an o-ring or something similair that seal the injector in?
Is it possible to pull the injectors and have them professionaly cleaned and recalibrated?
Is it possible to turn up the pump on this engine to increase the power a little bit, but without doing any damage to the hydro. transmission.
It does have glowplugs but I'm not sure how many work. Is there any easy way to test them?
Lastly it seems low on power and smokes a little more than normal (black smoke). Is this a combination of the leaking injector and the injectors being old?
Now some info on the tractor:
Kubota B8200 4x4
19hp 3 cyl. Diesel
3 speed hydrostatic transmission
Air and fuel filter just recently changed with no noticeable increase in performance.
Sorry this is so long.
I'm hoping to work on it myself as the Kubota dealer charges $45 per hour and I don't want to pay that.
Thanks for any advice.
Will
Kubota B8200 4x4
19hp 3 cyl. Diesel
Will
