Competition Ladder Bars-Which Style for Pulling??
Competition Junkyard, P-Pump's, cores
Just looking at some different styles of ladder bars... The use will be for sled pulling. . and some Daily Driving. .
The two styles are:
1. Bar with adjustments on one or both ends. . Hemi style adjustment. . pivots at both the axle and the frame.
2. The bar (or bars) mounted solid to the axles with a shackle connection at the frame. . (This is more how the Old style ladder bars were setup. )
The advantage to style 1. is that is will be a little simpler to build... Style 2 might be a little better for daily driving, because if the angle of travel of the axle is a little off the shackle will allow the axle to move some... but will it still do a good enough job at controlling wheel hop???
Opinions???
Thanks,
Bryan
Thanks JW. . I've seen pics of both... never paid enough attention to realize that EEP was using actual 4 Link design...
Anyone know if the shackle is solid mounted to the frame on EEP LB's?? or does it pivot at the frame??
Thanks
Bryan
EEP doesn't use a true shackle - they use like ~1/2" plate mounts at the frame and four separate links.
I will be running a design like your #2 listed above. We'll be welding them up ourselves and running 1. 25" rod ends at all the joints. Will probably build our own shackles out of 1/2" plate...
Chris
