I had bright boxed installed for quite a while and finally took them out. I always got a lamp out warning when I started the truck and had to switch the lights on and off to clear it.
Now, I am running "stock". It was a joy. Then I got the phantom chime. Finally now, I have a constant lamp out. Only problem is that I have no lights out.
Any suggestions:
a) What is causing it that I can fix.
b) Is there a way to disable the lamp out altogether.
Thank You in advance.
Any suggestions:
