Larger fuel lines/
Sporatic Fuel Pressure on SPA Guage: Lift Pump going bad??
dodge sport headlight
We would appreciate feedback on the need for larger, High Burst strength Fuel lines. What Dash Sizes would you like see, What brand of ends etc. If there is a market out there in TDR land we would like to evaluate it and seen what we can develop.
. Glenn Maurer EGR Severe Service Brakes.
only 2 sizes needed -6 for the mild bombers
and -8 for the HP junkies [on the -8 won't be many sold of these my guess]
there are different line lengths/fittings for the new ones v/s old ones [24 valve] as the lift pump moved
also some have pusher set up at the tank. .
I'm using Earls SS lines, Aeromotive elbows and Weber fittings, -8AN from the tank to the lift pump, -8AN forward from the lift pump to the FF, downsizes to -6AN for the Weber fitting. After the FF it's all -6AN. Works for what I have, can't really see a need for anything larger or all -8AN at this time. Just my opinion mind you, I'm hardly an expert.
Scott W.
Oh Man Glenn. I just missed yah.
I bought a full kit from Andy and Doug at ADT. Complete with two pumps, pre-filter for the pusher pump, and full -6AN Line from the tank, to the VP44.
BTW, Those drilled rotors Look AWESOME,, I'll get a story up on the TDR whenever the truck is runing again.
Merrick Cummings Jr
-6 lines for 99% of the trucks , only people in the top 1% , HVAC , Diesel Dynamics , Cumminstrokin , and maybe a few others would need -8 lines .
