It is more of a question... I like the looks of a "slight" lift (leveling kit) and slightly larger tires but think it is much more of a negative than anything else. Here what I think is the reason why I am stuck into stock rims / tires:
1. Stock rims fit snugly and few if any companies make rims with proper offset / backspacing. Rims with improper backspacing and non-hubcentric will cause excess wear and will perform worse than stock. Also because of backspacing issues tires will stick out and require fender flares.
2. With a 3. 55 rear end I am even further lowering my ratio and will make my truck more sluggish and take offs / towing
3. Larger tires "growl" more on the roads. I could get around this by finding a quiet tire but it still is a bit louder
4. larger tires put more stress on steering compnents and cause premature wear.
5. Larger tires are more tempramental. They require balancing more often and are more sucespitable to puncture and wear.
6. Larger tires in general reduce overall towing capacity. There are a few that offer load range E but they are few and far between.
7. While towing the tires will feel to "soft" and the sidewalls will flex causing a floating feeling.
Now, if you guys think I am wrong please tell me why. I really would like to add a leveling kit but feel I should leave well enough alone and maintain what I have.
thoughts?
Phil
thoughts?
Phil
