Last Question, Old School.....
2500 4WD Steering
Custom Truck Bed Photos
I'm decided on a 98 3500 12 valve with NV7100 pump and automatic. I'm using it for everday driving, pulling a trailer with one horse or two Harleys, while carrying a Lance 900 slide-in that weighs about 3000 to 3300 lbs. I want a reasonable amount of power, so as not to be embarrassed by 1st gens and Fords. I want great fuel economy, reliability and longevity. I rarely do anything but flatland driving, but emergency stops are commonplace down here. What do suggest in the way of modifications and equipment?
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, thermostatically controlled twin 14" Permacool electric fans, intercooler), modified 518 OD transmission, Gear vendors OD controler, R-134 refrigernt, louvered front fenders, 93 aftermarket smoothie grille, new Dupont Chroma-colr black, black-and-red rubber rubstrip, black headlights; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. To see my truck, CLICK on: http://albums.photopoint.com/j/AlbumIndex?u=1169022&a=10097213
Jesus saves!
I'll give you my suggestions:
215HP injectors, precision timing (pump timed on test stand, and the TDC pin located precisely), free flowing exhaust. I'd also suggest a BD torque convertor and valve body. Between those, you will have a moderate power increase, and you'll have the ability to install torque plates or slide yours forward if you wish and still have the power handling capacity.
Thanks PW!
Jesus saves!
[This message has been edited by jsimpson (edited 12-16-2000). ]
Get your boost and pyro gages. And as PW has said a free flowing 4" exhaust system with the pump precision timed (I'd go for a good 15/15. 5 degrees) You can later step up to a more aggressive fuel plate, and 300 or 370 injectors. a K&N filter properly installed is a plus.
BD, Bill Kondolay, or JRE will certainly help with the automatic trans components.
Frank Simkowski '98 Cummins 12v, Big Medicine. Got Diesel.
http://www.ecpe.vt.edu/~dfritz/RIDES/frank_s/classic92.htm
[This message has been edited by old school (edited 12-17-2000). ]
Oh yeah and forget fuel mileage cause you wont get any with your truck ASK ME I KNOW
98 2500 4x4 QC auto "one of the last 12 valvers- late Dec 1997" 305 70 16, K&N ,260/608 torque plate,EGT and Boost gauge under ashtray. Dog lover who hates cats so its gone too. Ring removed- Whats next folks????
RedNut,
I, with over 500hp, still get 18-20mpg with the truck. The mileage only got better with adding on the higher pressure injection nozzles and putting the injection timing at a higher rate of advance.
Chris Timochko
AUTO WURKS DIESEL R&D TEAM
1997 5sp 4X4, Espar Heater, A. W. D. HX40 turbo, ATS 3pc Manifold, BD 4" Brake, Marine Compression, A. W. D. Custom Tuned Injection Pump, A. W. D. Intercooler, A. W. D. 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, A. W. D. Water Injection, NOS Diesel Kit, A. W. D. 6" Chrome Exhaust System, BD No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s.
Project U96 - 1996 3500 2WD racer. A. W. D. Marine Ultra Low Compression, A. W. D. Teflon-coated Pistons, A. W. D. High Lift Camshaft, Ported and Honed Cylinder Head, Intake and Exhaust manifold; A. W. D. HX40 Turbocharger, ATS 3pc Exhaust Manifold, A. W. D. Water Injection, A. W. D. Custom Fabricated Fuel System, Race Spec A. W. D. /BD P7100 Injection Pump, A. W. D. Custom High Flow Fuel Injection Nozzles, BD Auto transmission and Custom TC, Weld Draglites, Goodyear Eagle Drag Slicks, 5" Single Stack Through The Bed, Mag-Hytec on Rear and Transmission.
