LE 7500 Monolec Trans Fluid
Where is Luke's Link?
Inexpensive Air Horns
Does anyone run the LE 7500 Monolec fluid in their auto trans? Was wondering if it lowers trans temps over the mopar stuff? Also, what other trans fluids are you guys using that lubricates/protects better than the mopar stuff? Any input would be appreciated!
Tony
I'm sure I can help you with your questions about the LE 7500 Monolec Power Fluid. I have worked for LE for over 23 years and am a Certified Lubrication Specialist buy the STLE. If you wish to email me I would be glad to answer your specific questions. Yes the LE 7500 will reduce temps in your trans. Your truck has the Mag-Hytec pan on it as well and they say that you should see a temperature drop by using that as well. They also say that by using the LE7500 and the Mag-Hytec pan that you will see even more temp drop by using both of them than by just using just one of them.
Sincerely,
Kevin Dinwiddie
