075.9Cummins
I’m leaking ATF thru what looks like a weep hole between the 48RE and NV273D. What’s the likely cause?
The weeping seems continuous with the truck at a slight incline in the driveway. I assume there is at least one seal on either the transmission output or the t-case input… or maybe one on each? Since the rebuilt transmission has 90,000 miles, I’d guess the problem would be a seal on the t-case but can’t find anything clearly addressing this issue.
With 365,000 miles I’ve rarely, rarely used the 4WD but it’s still a lot of spinning thru the t-case. Probably 500 miles on snow covered roads and a couple hundred miles on not so bad dirt roads. Earlier this year about ~75 miles total in low range creeping down steep trails in Utah and Nevada with a heavy truck camper. I’ve never had any issues with the t-case. Should I expect a rebuild at this time or just a seal, or two, or three?
Attached pic shows location of weep looking forward from under the rear of the transfer case.
What do the crystal balls show?
