My head gasket blew out on the right side back by the freeze plug area folks are referring to. At first I thought it was a bad radiator cap because it didn't show (or I didn't notice) leaking fluid down the outside of the block. It puked out fluid from the bottle during/after shutdown which went all over the firewall and fenderwell. The next time I pulled my travel trailer (after a new cap) I went about 100 miles before I noticed the temp start to rise and when I pulled over I noticied not only fluid on the firewall and fenderwell but also running down the block.
Regardless of popular sentiment here on the board CTD's do sometimes lose headgaskets. In fact the Monday I took mine in to be fixed I asked if "I was the only one they've heard of this happen to" and the reply I got was no way, they had one in the previous friday for a blown HG. BTW, they had the HG in stock and I was back underway the next day (example of a great dealer; not stealer).
Bottom line, check the freeze plug back by the firewall, check the radiator cap, and closely repeat closely check the head gasket area for signs on leakage. I could really see mine once I lifted the airbox out of the way. I guess it could be a cracked block but if it's hitting the firewall I'd suspect one of the other possibilities first.
Good Luck
