Noticed more and more smoke over the last couple of days. Popped the hood this am and did some looking around. There is quite a bit of fuel leaking from the base of the #6 delivery valve. Pulled the DV, everything looks good. Recent stainless steel washer (thanks McMopar), looks good. Rubber gasket is a bit chewed up. All surfaces in the IP and on the DV look clean and smooth... Put the DV back in, torque to spec (29# then 85#), hook up fuel lines, start and it's leaking more...
What can I, or should I do? Can't imagine that torqueing the DV down more is gonna gain me anything... Can't be loosing this much fuel... Don't like the amount of smoke... How do I make this thing quit leaking?
