leaking differential pinion seal
Front Axle U-Joint Replacement
ABS Problem
CFrance
Hello, my 2004. 5 with 11 1/2 AA diff is leaking oil from rear pinion seal. Is replacement of seal a problem?
The service manual says to remove axles and use inch pound torque wrench to turn input shaft for proper adjustment.
Must the axles be removed? Or can I just remove/replace seal and replace/torque pinion flange and prop shaft?
I thank you all in advance for your input
Mark the flange and the nut when you take them off. . No need to remove the axles. The nut is a 12 sided 36 mm I think--it's a weird size--be prepared.
Jay
