my #1 delivery valve is leaking... again... can I add a thin copper washer/gasket to help seal it or is that going to effect the fuel delivery balance between cylinders? (IE, would I have to add washers to all six valves)
any tips on getting this thing to seal properly? originally it was leaking because the guy I bought the truck from bent the #1 injector line out of the way when setting timing
which caused a couple small paint flakes to fall on the seating surface... I pulled everything out and picked the paint out... everything seemed fine for a while, but it's leaking again.
TIA,
Forrest
TIA,
Forrest
