Engine/Transmission (1994 - 1998) Leaking front seal B.O.M.
2nd Gen Non-Engine/Transmission Larger Fuel Tank for 3500
Hello Guys!
My front seal is leaking badly. I would like to know what parts I need to make this repair. Does Cummins have a sleeve to cover the groove in the shaft?
Thank!
TFP
What year is it? If it is a 12 valve, have you done the KDP? If not, now is a good time as you have to pull off the cover to get to the KDP. Replacing the C/S seal is easier when the cover is off the engine and sitting on a bench in front of you. :)
leaking seal
Crabman!
I left off some important info. The truck is a 1994 3500.
I have not fixed the KDP.
The return line is failing and makes for a fun start in the morning.
With 192,000 miles I still want to bomb the engine but never have done any thing except a 4" exhaust pipe.
Thanks for your help.
TFP
You might not need a sleeve for the front of the crankshaft. The front seal kit(for my '97, the Cummins P/N is 3804899) comes with a seal installer to press in the seal. I checked the location of the stock seal in the front cover before I removed it. On my truck, when I used the seal installer supplied with the kit, the seal ended up being farther in the cover, so now it's riding on the crankshaft in a different location. . Maybe they did this on purpose to provide a virgin surface for the new seal to ride on. I agree with everyone else. While you're going through the work to change the front seal, tab the dowel pin and check the other bolts inside the front cover.
