Truck is a '94 Auto. I bought the truck with a fuel filter reloction kit. The lines were all rubbed through so I just pulled the kit and replaced it with the filter in the stock position.
While trying to prime the truck with the new filter on, after about 5 pumps on the primer bulb, fuel began spitting out with each pump and no fuel was getting into the filter, much less to the cracked fuel lines. The truck has had some hard starting symptoms for the last 2 months while an employee was driving it. There doesn't appear to be any fuel leaking with the truck is sitting.
Question is... Is the fuel coming out a sign of a plugged pre-filter / fuel heater, cracked lift pump, or other? Is the overflow vavle a possibility for causing this?
Thanks.
Thanks.
