I just replaced my on my 99, all I can say is that it was a real *****. I didn't follow the directions to the letter.
Here is what I did, I removed all the mounting screws and bolts for the dash, where it would rotate down and out, but I didn't remove it. I dropped the steering column down with the seat all the way back, then rotated the dash down and unhooked the passenger's side from the bottom bracket and set it on a jackstand. Then, after several beers and scratching my head as I didn't want to disconnect the airconditioning lines and have to have it serviced, I took a hacksaw to the old heatercore and removed the lines..... Next step, after removing the old leaking heater core, was to figure out howto wedge in the new one without destroying the lines. Solution: I took a saw to the heater box where the core sits, cut out a square section on one end down to the bottom half so that the new heater core could stick out the side as I worked it in. With some gentle cussing and another beer or two, I easily worked the new one into place without destroying anything. I hooked up the lines and tested it to make sure that I hadn't causes any leaks in the new core, it tested out fine, then took some 3M plastic glue and reinstalled the cutout section of the heater box, reinstalled the dash and steering column and you could never tell it had been hacked.
By the way... . the stealer want's around 1100 bucks to change a heatercore out.
Morph.
