Leaking injector pump help.
Bed Coming Apart
Where is Number One on VP44?
I just discovered that the Inj pump on the Red Ramcharger is leaking. Doesn't seem to be leaking why running, just after it has been shut down. Seems to drip about 12 drops of fuel that falls onto the Power Steering pump and rolls on down until it drips on to the floor. I'm certain that it is fuel. This is a very recent thing and I have not moved the pump. It's probably just a seal, but I'm wondering if there is a chance of just something needing to be tightened down. I can't pinpoint where the leak is located on the pump. Any ideas? No clue about the age of the pump. P. O. said the pump was buil a few thousand miles before I picked it up. Doesn't seem to be running any different either.
Any suggestions?
Andrew
Nope. Still checking things out and can't be sure but it looks like the seal between the pump body and rear "distribution" housing is leaking. I was able to tighten the torx screws a bit, but it's still there. Just can't see the back of the pump enough to tell it's coming from elsewhere.
Andrew
my pump did the same thing however, due to leek it was loosing the prime and hade a hard start. If it is the seel between the main body and dis block it requires the entire pump to split. I now have a new pump. good luck
