Leaking Oil Filter Problems...
Priming engine oil system
Silicon Numbers from Sample
Up until now, I had let the dealer change the oil on my 2004. 5 Dodge 2400 Cummins Turbo Diesel since they threw in 5 years worth of oil changes when I bought the truck. A week or so ago, I noticed my oil filter was leaking, so, I decided to go ahead and change the oil myself. When I reached up to remove the MOPAR oil filter, I noticed that it wasn't completely tight. I also noticed that when I drained the oil, it seemed that it may have been diluted with Diesel fuel. Anyway, I went ahead and changed the oil (Mobile 1 5W-40 Synthetic) and I put an aftermarket Purolator Filter on. After pre-filling the new oil filter and adding 11 quarts to the engine, I cranked it up and checked the oil pressure. I then looked out to check for leaks and the oil filter had puked out over 4 quarts of oil. I shut it down immediately and rechecked the oil filter, but it was tight. Since the Dodge dealership parts department was closed, I went and bought another “premium” oil filter (Mobile 1) and installed it with similar results. I ended up reinstalling the old MOPAR filter and no more leaks.
I double checked the aftermarket filter numbers and they were correct. I also checked the center thread of the oil filter mount by hand and it seemed to be tight.
Has anyone had this problem before? Any help would be greatly appreciated.
Was it double gasketed? The old oil filters rubber o-ring sticks to the housing, then the new rubber o-ring mashes into it.
Pukes oil every time.
Happened to me years ago when I was in a hurry. Didn't check to see that it was removed. It will never happen a second time.
That's what I thought also. I swear, I thought the gasket was still on the old oil filter and not on the housing. I am wondering if I am going blind!:eek:
