Had a little extra time on Tuesday so I decided to play with the pump. The truck has 288,000 miles on it with the original pump, new (stock) injectors at 180,000 and a Banks Stage 3 kit (housing, filter, exhaust, intercooler). For the last six months, I have been unable to get the boost above 15psi and the EGTs above 900F. I decided to take a look at the pump and turn in the power screw a little more than it had been turned in 1993 when we did the Banks kit.
Well, the collar was against the lock nut already. So I decided to remove the power screw and take the collar off. After removing it, I turned the screw in two more turns than it had been.
WOW... what a difference. Boost shoots right to 19. 5psi (that the wastegate pot that is on there now) and pulls like my race Audi (no kidding). Third and fourth are incredible now! EGTs are just about 1050 on a long hill in fifth after lugging it from a low rpm at WOT.
The only downside is the idle... it's at 850 now. A little high for a manual IMHO but I'll live with it.
When I went to see if I could turn down the idle, I noticed that I have a leak coming from the pump. I am getting about 1 drip per second at idle coming out of the spot that the throttle linkage (for lack of a better description) goes into the pump. Is there an o-ring in there that I can replace or am I in for a new pump?
While the pump may have 288,000 on it, we have always treated her well by changing the fuel filter and until now, the pump has never been overworked. Until this tweak, it took forever to get the boost to 19psi and only when fully loaded on long grades. Now I know that the lock collar was holding everything back and we could have had much, much more power out of this thing for the last 10 years... oh well.
Any suggestions on the leak?
Thanks in advance,
Mike O.
Thanks in advance,
Mike O.
