There is no timing chain cover. You must mean cover in the front gear case. It is sealed with silicone, not a gasket. I had mine off a few times on 06. Once to do the cam install. I didn't replace the crank seal at the time, and it leaked. So I had to take it off again and put in a new crank seal, which should be done anytime the cover is removed.
