I have a leak where the transfer case mounts to the transmission. There is one mounting nut that is pretty loose at the bottom of the transfer case. This is where I think the leak is. It is a 9/16 nut. The support bracket under the transfer case makes it almost impossible to get a wrench on it. I should have mounted the transfer case to the transmission before installing the support brackets. #@$%!.
Can anyone suggest a tool that might do the job?I did this install months ago and didn't think that one loose nut would matter.
I guess a more important question is should there be fluid there in the first place?If yes I just have to tighten up that loose nut somehow. If no fluid
should be there it could be from the transmission or transfer case. Which means a seal needs to be replaced.
Your thoughts
Mike
Have a safe New Years.
Your thoughts
Mike
