Leaking Water Control Valve
Tires
drum brakes
My water control valve is leaking (valve on heater hose on the drivers side). Its not too bad but it needs to be replaced. I called a local dealer and they said that the part was discontinued. So, I went to NAPA, they said that my rig didn't have one. But it obviously does if it is leaking (they aren’t too smart at NAPA). :rolleyes: Then, after checking at another parts dealer, I was again informed that the aftermarket part was discontinued.
Do any of you know where I can find one? I just filled my cooling system with $42 of CAT long life formula, and I don't want it all dripping on the ground. Thanks for your help.
Mike
Crazy thing is, I'll bet your local napa store has one on the shelf. But if he's too lazy to look it up, I'm not sure I'd want to reward him either :mad:
