I installed a ATS 3 piece exhaust manifold on my '96 (stock) about 3-4mos. ago. Tonight I looked under the hood carefully, and noticed the no. 2 exhaust runner and part way into the no. 1 runner, the metal has a blue look to it. It's hard to tell if no. 5 & 6 have the same color, as it was under the cowl and evening was coming on. Is this normal for the ATS manifold as it ages or do I have a fuel issue that I need to address? The truck runs great with no apparent issues. The old cast iron manifold never showed a problem, but it was sure shrinking.
One other item. I just purchased a '96 CCab with 45K on it, and it has the 4. 10 rear gears. I wasn't use to the higher revs, as my other '96 has 3. 54 gears. Does the mileage suffer much? I know the sound level is definetly increased. I pull a 5th wheel, so I hope the lower gears will be good for that.
