Details here: TDR Privileges
The answer is no, you can not order a Laramie with cloth seats. Again, no to the bun warmers with cloth seats. Why would you even want bun warmers on cloth seats.
Get the leather. I have the stock cloth seats and they are the ugliest and most easily stained seats I have ever owned. My '98 cloth seats looked like new after 8 years but appearently that designer no longer works there.
I want to put Katzkin leather in the truck. Much better quality than OEM, and less expensive to boot. You can order heaters from them, but I would want the OEM switchgear for it. As for the heat, the older I get the creakier my back gets, and that heat helps out when it's cool outside. Sounds like the original Dodge leather might be the easiest way to go, but just wanted to check into it.
my ticker doesn't run on all valves so my blood flow isn't too good [when it gets below 10°c, i am cold], and i want heated seats with my cloth. . i've been pretty much yearly buying those cheap heated seat pads when they go on sale in the fall. . i really need to get an espar...
