led lights for trailer
Featherlite vs Exiss open car trailers
Sliding hitch recomedations? (besides Pullrite)
saw a link a while back on here about these figured i'd try them and see if it's a gimmick or hard to install.
well here is the website http://www.ledtrailerlights.com/
these things are awesome!!!!! very bright to normal camper/trailer lights and are truly plug and play. No resisters are needed at all (used as just running lights) i thought the single bulb factory ones were way to dim so i tried these and wow is all i can say. They are kinda pricy at $11 each but worth it. :cool: just pick the trailer/rv style 14 led and your good to go!
I just replaced all my lights on my TT with those. The Running lights have 3 LED's that face at a 45 deg angle for front or rear visibility. If you have seen the photo gallery on these then you know what they look like. They are a sealed unit with 2 wires. Black is positive white neg. They are exactly the same size as the POS Peanut bulb light all RV"S Have so you won't have to drill new holes. I took all of the putty "dum-dum" off and used the gasket it comes with then used a little clear silicone on the top and sides. Highly visible even during the day. Pricey? NO! Just something you will NEVER have to replace.
I also bought the 24 LED Lights for the BM #84 square Tail lights. These fit right inside the lense and the socket is a normal style and the LED's are red. The picture you see is exactly what it looks like. So now the only regular bulb I have is the back-up Lights... .
