I have had my backup light wiring done for some time now but I wasn't really sure what type of lights I wanted. I came up with this . I used the same foglights I have on the front of the truck and fitted them into the rear bumper for a nice clean look. I took a standard 4" rubber light grommet that I bought at a trucking parts supply and cut about 1/2" out of it, then remelted it back together to reduce the diameter to fit the fog. I played with hole sizes in cardboard before cutting my bumper. The result is a nice snug fit. The standard fog bulb is 37. 5 watts and has the tip coated to direct the light back towards the reflector but it limits the amount of light that is thrown forward, or in my case backwards. I replaced them with 885 bulbs which are 50 watts and uncoated, resulting in a much more floody pattern. They throw a pretty good light behind the truck and I can even aim them by moving them within the grommets. I thought heat might be an issue but after having left them on for 15 minutes, they are not any warmer to the touch than the stock bulbs. I had a little room to play as far as the placement went left to right. I used a cardboard circle to locate the lights in different places before commiting to this layout. It is about the same spacing as the front lights and gives a nice even light pattern where I can see it in the mirrors. I have them wired through a relay and they will come on with reverse, with the ability to turn that function off, and also I can turn them on manually if needed.
