leveling kit+banks stinger +
Replacement pads for 4 wheel disc trucks
Block heater...yea or nea
I am looking into leveling kit,so I can fit 315s and banks stinger +
any advice on my choices. a little scared about blowing somthing up. Ihave a 98 2500 quad cab 24 valve 8 ft bed 4x4
thanks -- email address removed --
Let me be the first to welcome you to the TDR.
I do not have an answer for your questions, but I do have a partial solution. There is a search function and you can find all sorts of good info using it. I tried a search for leveling kit and got a few links to some good info. Click here to see the results. If you want to search yourself the button for searching is in the upper right on the screen.
Once again welcome to the TDR and good luck.
Banks, I'll touch it.
Do not buy Banks Stinger kit. You can get the same results for a lot less money. Search the board for a good while before you buy anything.
Welcome to TDR-land. :D
If you need more info about Banks... ... .....
Be sure to have a couple of hours with nothing to do.
First... . pull on your NOMEX gloves, the asbestos coveralls, a welding mask (the darker, the better) and strap youself down tight to your chair.
Go to the search box at the top, enter Banks, select to search all forums.
FLAMING WILL NOW BEGIN :D :eek: :eek:
Spend one hour each day on this web site for three months, then make some decisions. You'll be glad you waited.
Task125, read my sig. , I started with a Banks Stinger+, the only thing left on my truck is the Banks 4" SS exhaust system, and I think it is fine. Listen to these guys, they aren't leading you astray.
Larry
banks...like Dr. Pee
I wouldn't buy the Banks kit either. A LOT of people who are new to these boards will first post about what we think of the Banks, or Dr. Pee kit they are thinking about getting.
I met a guy in the lunchroom today who, we had seen each other before, just never really talked and he said he was going to get a set of Dr. Peeformance injectors(Dr. Pee makes injectors??). I told him about this web site, and left it up to him, no pressure. It's amazing how most newbies only know about Banks or Dr. Pee though.
Andrew
TxDiesel,
It's amazing what a lot on $ on advertising can do. If you ask anyone who isn't on TDR about performance, the first thing that comes to their mind is Banks... Everybody always asks me... do you have a Banks Kit? I say no, I have more power than that and it was cheaper... . then they get interested.
Corey
