Leveling Truck
will slide in camper work with megacab?
Insurance Premium Question...
I would like to level my truck. I would like to try and get some feedback on lowering the rear end instead of raising the front. I have heard some talk about moving the spring stack on the rear around to lower the back end.
Is this a smart way to go? Does anyone have the steps involved with attempting something like this? Any special tools or skills needed?
Thanks, Jeff
If you do a search on the rear springs and lowering the rear end you'll find several that have done just what you said. i. e. remove the spacer blocks. I beleive that this will drop the rear end about 1 1/2 inches. They have pictures and tools listed also. good luck with your project. and
Keep grinnin,
Walt
I had tried to search on these types of topics and could not find anything and was why I posted? Are there settings within the searches to help find items?
I searched on lowering rear end... No hits at all
rear springs found several items but I could not find anything referencing the items I am trying to find.
It must be something on my setup that is limiting the search results as I would think it should be finding better results than what I am finding.
Thanks, Jeff
I lowered the rear on mine. easy, just put the spacers on top of the springs instead of the bottom it lowered about 1 3/4". all I had to buy was new center spring bolts. It looks great and rides like stock. On the plus side when you lower the rear there is far less of a chance of death wobble due to the increase in castor. I should have a new pic of the truck in my gallery, It's the one after it has been debaged
Thanks for the replies. . I read thru the Klenger site and it had a link to a TDR topic about this very procedure. The truck they are showing is the exact year of my truck so I am very confident it will work without any problem. There was a valid concern mentioned about the caliper removal bolt being behind the spring which could make changing the pads a concern. Glad I just this weekend changed my pads. Maybe next weekend I can go about loweing the rear.
Thanks Again... . Jeff
Klenger site had a link to a TDR forum. .
https://www.turbodieselregister.com/forums/showthread.php?s=&threadid=101508
Its topic was "Spacers removal for lowering rear end" ??
Can someone explain why I can do a search for "lowering rear end" and not find this? Something must be wrong somewhere to not allow the search to find this?
