So the other day I noted a light out no biggie right ?
Well I remove the lens cover and found the bulb black of course but, it's stuck in the socket. The socket is a combination assembly and moisture gasket made from a funny soft white plastic. (two wire leads with plug)
The factory has put that fleshy brown colored poo-poo in the socket to prevent the bulb (194 type) from sticking and aid in moisture incursion.
This Poo-Poo has eaten and softened the plastic socket !
As I work to remove the bulb the entire socket falls apart, cracks and is a pile of (you know what) in my hands!
So... down to the dealership... ah... part number 56018807 2 each required...
Holy cow $15. 30 apiece with the two wire leads and connector assembly!
The 194 bulb draws . 33 amps
Type 161 bulb draws . 18 amps (ashtray bulb) less luminance= less heat
Hence I belive the higher current 194 bulb cooked away with the Poo-Poo and made the mess to begin with... now I've prepared the socket with electronic grade silicon grease and placed the 161 bulbs into service.
The drop in license plate luminance is not going to draw any attention from law enforcement... . it's lit! (some of you guys may appreciate less light here)
I share this with you guys so you might be able to get the Poo-Poo out of your sockets and drop to a lower wattage bulb to prevent having to pay for a factory error. I was pleased to see that the new fresh sockets arrived with no Poo-Poo in the hole.
Nothing like doing a $1. 39 bulb replacement that ends up costing just under 40 bux by the time your done
William
William
